My Maytag MFI2568AES Water/Ice feature wont operate. If I unplug the refrigerator and power back up it will work once. If I hold the door open with a glass on the dispenser paddle and press the door switch it will work but with door closed again it will not work. I'm hoping its the switch but fearful of a control board. Any advice is greatly appreciated.
Thank you,
Peter
UPDATE: I replaced the switch (little harder on this model with wires foamed into the side) and it did not solve the problem. It also has stopped working intermittently which leads me to fear it is the control board. Is this a straightforward fix or should I cal a technician?
Thank you.
