My wife used the oven yesterday and it worked fine, so I'm not sure if she did something. Range is electric gallery model. The burners still work fine.
Today, I can press the quick preheat button, bake, broil, or convect, then enter the temperature. When you press start though it shuts off. The only way I found to get the oven started is to press convect then convect convert. It does turn on doing this for some reason.
Any ideas of what I should look into for this? This house was purchased with all new Frigidaire appliances, and in a year so far they have all had problems...
Here are your parts Parts for Frigidaire LGEF3045KFB Range - AppliancePartsPros.comTry unplugging the unit or turning the breaker off for half an hour or so to see if the control board will reset. If this does nothing then odds are that the control board (item 20 in section 03) is bad. You may also need a new overlay (item 20A in section 03). Looks like it is peel & stick and often they get damaged when tying to remove them. |
THIS FORUM IS DEAD!!!!!!! |
