Greg jackson
#1 Posted : Sunday, October 25, 2009 6:21:32 PM(UTC)
Greg jackson
Hello, I have a Maytag side by side refridgerator. The fridge is warm, checked freezer coil, massive ice build up. Defrosted with hair dryer, fan is working, heater coil ohms out/not open. tried jumping sensor, also opening sensor lead, coil did not heat up. This Maytag has an "adaptive defrosting system" ? Looks like by the diagram there is a small board near the controls in the fridge section. What commonly goes bad with these?
#2 Posted : Monday, October 26, 2009 3:43:56 AM(UTC)
here are your parts
Replacement parts for MAYTAG MSD2756GEW | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16010154.pdf
Not sure what this means. If you are referring to the defrost thermostat, it should be 0 ohms when frozen. Note: that it opens just above freezing.
Sometimes when they go, you can actually see that they have bulged out.
The adaptive defrost boards usually just do not start a defrost cycle, I am not sure whether it is the electronic timer or the relay/triac as it is just a replacement part.
See Page 2-15 in the manual.
