AppliancePartsPros.com
Appliance Repair Help
Kenmore Elite Electric Range - lower oven does not work after "self cleaning" cycle
After running the "self clean" cycle on the lower oven - it does not work - it does not get hot at all.
Upper oven works fine.
Removed oven temperature sensor, checking it for continuity with a meter. Temp sensor measured 1071 ohms - within specs according to manufacturer.
This seems to be a relatively common problem with this range. Others have mentioned a possible "control board" problem - but would that not also affect the upper oven (which still works fine).
Any suggestions?
Thanks, Jim Craig Healy, Alaska
Replaced lower oven temp probe - oven still does not work.
Removed lower oven heating element:
It measured 17 ohms - what is the correct resistance amount?
