My 61 Kenmore dryer says to use lubriplate 89318 on the front drum skids/bearing. (there is a groove in the felt that runs between the two pads - it says to fill that channel with the grease. 89318 is not longer available from Whirlpool. Is this just white lithium grease? What do I use? :confused:
A high temp type of grease that does not run when warm is the best. Use it sparingly
