Electric range front right burner labeled fast boil, will stay bright red even on low setting. Would replacing control for that burner solve problem? Looks like part number AP 4337066. Thanks
[COLOR="Blue"]Would replacing control for that burner solve problem?[/COLOR] Yes it should as long as you have the correct part number for that infinite switch. |
THIS FORUM IS DEAD!!!!!!! |
