I am trying to find a way to replace a refrigerator gasket for a Montgomery Ward HMG 1743-4/1744-4 refrigerator. I'm not sure exactly which model number the refrigerator is because the sticker is worn. I found a model look-up website that allowed me to use wild cards for the missing numbers and got those two model numbers. They are both in the range of 16.5 cuft. One is like 16.54 while the other is like 16.58. They are both very old, made in the early to mid 80s. I tried searching the seal by dimension but had no luck. The seal has shrunk some but it appears to measure 28.25x38.75 and the door itself is 29x39. If I can't find the exact size I need, is there any professional way to make one close to that size work? Thanks.
Angela
I was just informed by a rep in chat that you guys cannot advise on aftermarket or customizing parts. Somehow I doubt there are OEM parts for this fridge but if anyone knows if I can get an OEM part, thanks. I'm having a hard time finding one.
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I need a timer defrost. For model hmg-1743-4
