The model number is slightly rubbed but think it is. 9E or 8 080scgg. There is a part number on this label 3380610. What I am dealing with is water drips down float tube, replaced float and switch below, attempted to level, could not find level spot on machine that seemed suitable other than top of machine door. Still drips. ?:eek:
I cannot find any info using the numbers you gave.
You replaced the float and the switch. How did you find those without a model number?
To level it you can usually use the top of the lower rack. This should let you level it side to side and back to front.
Check that the bottom wash arm is OK and all the holes are clear. Sometimes you can get a crack or a partially plugged hole that will spray water at a weird angle and cause a leak.
Since you replaced the float I am assuming that you cleaned all the parts in that area. They have to be clean to prevent capillary action wicking the water up.
Try opening the door when the unit is full to see if it still leaks. If it does then carefully check for a small crack of pin hole in the tub. |
THIS FORUM IS DEAD!!!!!!! |
