fasta6
#1 Posted : Wednesday, November 12, 2014 4:50:00 PM(UTC)
fasta6
Originally had a F4E4 error. Found hose had worked its way off the sump. Replaced the 4 hose clamps in that area and reassembled. After reassembly, received a F2E2 error, cycled the power. Now error codes now. When we start a cycle, it will drain and fill, but never runs the pump, it will eventually cancel the cycle.
Possible the diverter motor is just wet? Any chance it will dry out and work again, or just replace the diverter assy? I don't see anything else in that area that could have been damaged by getting wet. Did I miss something?
fasta6
#2 Posted : Saturday, November 15, 2014 4:29:23 PM(UTC)
fasta6
OK, I'll answer my own question for the benefit of others. After installing the new clamps and reassembling, we ran a fan directed at the bottom of the machine for a few hours. After that, the machine functioned with no errors with the exception of the diverter being installed improperly. Not sure what was wrong with it, just took it off again, looked at it and reinstalled. Working fine now.
