Limacaller
#1 Posted : Sunday, November 9, 2014 6:39:06 PM(UTC)
Limacaller
Hi everyone,
I have a electric Magic Chef dryer that all of a sudden has no power. Light does not come on and seems dead. It Does make a clicking sound when I turn the knob though. Circuits seem fine. Any suggestions would be appreciated.
#2 Posted : Monday, November 10, 2014 1:00:29 AM(UTC)
A model number may hyelp others help you.
Find your model number - AppliancePartsPros.com
Since the drum light no longer works I would start by checking the power.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
