I have a ge DSXH43EA1WW dryer that doesn't dry very well. It males good heat, so I took it apart to clean the fan and ducts, and I noticed the felt drum seals and foam blower seal appear to be letting air past. How much movement should be allowed by the felt seal? I take the top off and lift the drum straight up and I get a gap just over 1/8". Please help
