kim2308
#1 Posted : Wednesday, November 5, 2014 4:18:06 PM(UTC)
kim2308
Please help my electric stove the oven the bottom burner will not kick off top burner works fine. :confused:
#2 Posted : Thursday, November 6, 2014 2:40:00 AM(UTC)
Parts for Whirlpool RF365PXMQ0 Range - AppliancePartsPros.com
I am not sure what you mean by "kick off".
If you mean that it will not shut off and it is red along it's entire length then odds are that the control board/timer is bad.
kim2308
#3 Posted : Thursday, November 6, 2014 3:05:19 PM(UTC)
kim2308
Yes Thank you I was meaning shut off the bottom element will not shut off it stay's red hot. The top element will shut on and off like it is suppose. Thank you for your reply.
#4 Posted : Friday, November 7, 2014 1:12:14 AM(UTC)
Sounds like either the contacts of the bake relay on the control board are welded together or the electronics that control the relay are shot and always energize the relay.
File Attachment(s):
RF365.pdf (150kb) downloaded 0 time(s).
