J.francisco
#1 Posted : Tuesday, November 4, 2014 11:31:49 AM(UTC)
J.francisco
I have this error 5D which is for suds and then after minutes the washer shows the error F-
I purchased and install a new pump and again the 5d shows again. I ran the service test and everything looks like is working. Any Ideas..???
Thanks!!!
sidfink43
#2 Posted : Thursday, November 6, 2014 5:10:20 AM(UTC)
sidfink43
Unfortunately with Duets the standard repair practice, even for Whirlpool techs is to replace on a trial and error basis.
It may be the control unit, but I would start by replacing the pressure switch. A bad one can cause that problem.
If you buy the parts from this site and they don't fix the problem you can return them.
