spartans01
#1 Posted : Sunday, October 25, 2009 8:10:42 AM(UTC)
spartans01
Drain motor will not drain water and also will not stop running/ or cycle to next function. Drain pump/motor will not stop running unless I turn off power from power button..
Any ideas on what could be my issue?
sbk101
#2 Posted : Monday, November 2, 2009 12:37:36 PM(UTC)
sbk101
your issue might be the same as everyone else's. Circuit board/control module. read other posts with Bosch DWs contunuing to run and being stuck in cycle. Check this out:
Bosch Dishwasher Drainage Problem Fixes
