AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washer won't rinse after fixing spinning problem
I replaced the shift actuator for a spinning problem. The washer would stop and the lid would unlock. Now it won't go to rinse cycle except on the light casual cycle. It will start to fill then drain and go to the spin cycle. This is happening on a new control board also. No codes are coming up. All the pins on the connections look good, nothing obvious visually. Any suggestions?
Washer Repair
