Unit stopped working, neither freezer or refrigerator was cold. Light, fans all working fine. When I turn off the the unit by either unplugging or turning the freezer control to off and back on the unit works fine but will only run for ~1 day then stops again. i have replaced the control temperature, part 5304496561, and the control defrost, part 240375803, and still getting the same results. Where should I look now?
What is the cold control? I cannot find it in the parts listing for this unit. The freezer temperature control should be Part number: AP2151626
Click on the picture for more info about this parts. Instead of turning the unit off the next time it happens just turn the freezer temperature control up and down some (not to off). If the unit fires up then this thermostat is the likely culprit. |
THIS FORUM IS DEAD!!!!!!! |
