danhicks
#1 Posted : Tuesday, October 28, 2014 7:25:16 PM(UTC)
danhicks
Hello Gene,
The freezer works fine. The refrigerator doesn't work. This is the french door model. Model# 596.73503201.
I noticed the back of the freezer was froozen and the Vert Mullion Assy was very hot to the touch. I called the Sears parts/help and they indicated the Vert Mullion Assy should be replaced. That was a four day $144 waste of time.
I got on line and did some checking. I opened the back of the freezer and checked the thermostat, and heater coil -both checked okay. Thinking it was the Adaptor Defrost Board - i ordered it from your site. That didn't fix the problem.
I thought the evaporative fan might not be working and opened it up to check. When i touched the fan it started moving and appears to be working although not very fast. Is it connected to the damper contol circuit via some demand signal? How do i check if the damper control is bad or if the evaporative fan motor is not working properly? Or is there some other area i should check?
Thank you very much for any assistance you can provide.
Very Best,
Dan
#2 Posted : Wednesday, October 29, 2014 4:36:59 AM(UTC)
If the evaporator fan motor has 115 volts stamped on it, plug it in the wall outlet. If still not up to speed, order a new one on this site.
danhicks
#3 Posted : Wednesday, October 29, 2014 5:18:05 PM(UTC)
danhicks
So how do i plug the motor into a wall outlet and how do i know what is "up to speed"? Is this a variable speed motor based on input from the damper contol? Could the damper control be bad? In addition, will you please explain how to take the plastic assembly off so i can access the damper control unit. I don't want to force it and don't see any obvious releases or detents.
Thanks,
Dan
#4 Posted : Thursday, October 30, 2014 1:26:56 AM(UTC)
Use an old lamp cord to plug the motor in. The damper housing ends in the freezer. Probably need to pound it out from the freezer side.
