I have a lg dishwasher that will fill with water, then drain before the cycle starts.Then it will run in a cycle with no water. If I select a cycle and let it start filling, then open the door and interrupt the filling process,then shut the door it will finish filling the and run the cycle with water. The bottom spray arm does not seem to be working.
