KariWheaton
#1 Posted : Thursday, October 23, 2014 4:20:55 AM(UTC)
KariWheaton
Oven is clicking but doesn't heat up and temp on screen reads 100 degrees.
#2 Posted : Friday, October 24, 2014 1:18:26 AM(UTC)
Check the power to the unit.
The controls use half the line (120 volts) but the heating elements require the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
