Have a Jenn Air SVE47600W. When using the oven it flashes FC then F- and beeps. Oven will heat to about 300 degrees then receive error code. What is the likely culprit?
Here are your parts Parts for Jenn-Air SVE47600W Range - AppliancePartsPros.comBelow is a service manual You will have to join the site and be logged in to be able to download it. Also it covers many units so you have to be careful to ensure that the section applies to your unit. http://appliancejunk.com...&id=385;t=1413712560This will probably be a pain to find as it is a communication error. The first thing to try is unplug/remove power from the unit for a couple minutes to see if the unit will reset. If that does nothing then try the following. Connector Cleaning / Checking Unplug the unit Open it up Remove the ribbon cable from the keypad to the control board at the control board. Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol. If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here. Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates. Reconnect everything and give it a try. If that does nothing then the problem is most likely on a board. Check the board for overheating etc. Check the solder side for bad solder joints. Often they are a duller silver color and/or have pin holes. gently wiggle the components/plug/receptacles white watching the solder side of the board to see if it's leg moves in the solder. |
THIS FORUM IS DEAD!!!!!!! |
