Rank:: Member
Upright freezer showing E8 code and alarming. Temp showing high but freezer is cold. Also left panel looking at front of freezer seems hot although breakdown shows nothing behind panel. Can anyone give and information ?
Here are your parts Parts for Frigidaire LFFH21F7HWG Freezer - AppliancePartsPros.comThermistor Error Mode: Alternating Flashing Display of E8/Temp or E9/Temp Upon entering the Thermistor Error mode and an open thermistor condition is present, the display will alternately display an “E9” for 0.5 seconds and “-10°F” for 0.5 seconds (-23°C if in Celsius mode). If a shorted thermistor condition is present, the display will alternately display an “E8” for 0.5 seconds and “-10°F” for 0.5 seconds (-23°C if in Celsius mode). The thermistor is at the bottom of the lisying of Section 07. Could be a bad thermistor. Also may be a bad control board. If unplugging the unit for a minute or so resets everything then I would lean towards the control board. Also check that the evaporator freezer fan runs OK. |
THIS FORUM IS DEAD!!!!!!! |
