nicyoung07
#1 Posted : Sunday, October 12, 2014 8:29:59 AM(UTC)
nicyoung07
I have a whirlpool washer model LSR8010pq1. What is happening is the washer will go through the cycles properly but, when it gets the final spin it will not spin or pump the remaining water from the tub.
I can get the final spin cycle to engage and run after resetting the cycle several times. I have noticed that when the final spin cycle starts up, the agitator and tub moves very slowly compared to normal before getting up to speed. The clutch was replaced about 2 years ago on this machine. Could be possible that the clutch has gone bad again or could it be a different problem?
sidfink43
#2 Posted : Monday, October 13, 2014 3:37:47 PM(UTC)
sidfink43
If it spins ok after the agitation cycle that implies there is nothing wrong mechanically and the problem is in the timer.
