First last week I notic end ice cream was not as cold as normal. Pulled out freezes unplugged it plugged it back in. The next DAT all was well in freezes. But the fridge was slightly warmer than usual. Few days later, all. Warmer than usual. So I've taken all to liner parts out in the freezer, and the fan that is suppose to be blowing cold air down into the fridge is not turning. It spins freely, I disconnected it and Unhooked the fan, plugged it back in and. Nothing. I think its the fan motor, but anything else I should check like the defrost thing before buying a motor?? Thanks for the service.
I unhooked fan motor, and plugged in the power, I've got 110 V on the red wire, and about 1.5v on the white wire. Im not sure I understand the resistance/ continuity thing, but with the motor unhooked, red lead to where red wire should go, and black lead where white wire should go, my meter beeps. Ohms were about 5 I think. Anyone have any ideas?? Thanks again for any help.
Replace the evaporator motor AP5177416, your most probable problem.
