Error code displayed SY EF. unplugged fridge for 10 minutes, plugged back in, & it worked, started getting colder. It went to normal operating temp. The next morning the error code was back. Unplugged, waited, and plugged back in, worked fine. This afternoon error codes were back. Pulled out back panel of freezer, and the fan is working. Could it still be the fan, or is it the control board?
What is running/not running when it fails?
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Keeps operating just has code showing
Rank: Guest
Still working just shows error code sy EF
Rank: Guest
Rank: Guest
This is a Frigidaire side by side showing H 8 and seems to still be cooling I’ve unplugged and reset codes come back and beeping is extremely annoying
Rank: Guest
