terry3567
#1 Posted : Tuesday, October 7, 2014 3:28:02 PM(UTC)
terry3567
Is there anyway of resetting the temperature settings in the control knob or somewhere on this model range? I have read some posts for other models that they are able to reset theirs by 25 degrees max., but not sure if my oven can be adjusted.
#2 Posted : Thursday, October 9, 2014 2:42:48 AM(UTC)
Parts for Frigidaire FEF322BAWM Range - AppliancePartsPros.com
Looks like the unit cannot be calibrated.
Click on the thermostat (Item 12 in section 02) and the knob (item 32 in section02)
I cannot see any way to adjust it.
Here is a link
http://www.applianceaid.com/ele...ics.php#standard-control
Take a look at "How to change a standard controlled oven temp:"
