Hi, just replaced the glass on my oven door (thank you YouTube!) however, on cleaning up and getting ready to put the box in the recycle bin...the Foil Tape...where does that go? my daughter had cleaned up the broken glass and "oh yeah, there was some of that..." thanks in advance...Deb
THIS FORUM IS DEAD!!!!!!! |
Thanks Den, so the tape goes right below the lip where the glass is inserted? or does it overlap a little?
thanks for the reply! Deb
Looks like it goes about 1/4 inch down from the top of the glass. |
