Barclay
#1 Posted : Monday, October 6, 2014 11:02:04 AM(UTC)
Barclay
I have a 6-9 Duel Radiant Element. The 6" does not work put the 9 does work. What do I need to replace?
#2 Posted : Monday, October 6, 2014 11:57:28 AM(UTC)
Parts for Frigidaire FEF368GCA Range - AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/p...ingfield/316441491en.pdf
Unplug the unit and check the element with a meter.
I do not know the wattage is so cannot tell you what the resistance should be but you should see some resistance for both coils.
If the outer coil is infinite resistance then replace the element.
If both coils have resistance, replace the infinite switch.
Also check that the wires to the element are OK.
