Hi folks, My washer usually runs through all cycles but sometimes gets stuck in various places just before the last spin / rinse / spin cycles. I can usually get it to spin by turning the dial around to a different spin cycle. There is a mild burning plastic (electrical) smell coming from the timer when this happens. I changed the timer and the problem went away for a few months, but now it's back. My question is, should I change the timer again or is there another part that could be the cause of this? Maybe a control board? Thanks for any help.
