The front panel lights on it was slowly "flickering out" and then got dimmer and dimmer and now it won't turn on at all. Its's worth mentioning that I would push the start button or the mode button on the panel and most of the time nothing would happen, and i had to push for 2-3 minutes sometimes before anything would happen. And it's full of water in the bottom. Please be aware the im a novice in the "Fix-It" field. But willing to try anything!
THIS FORUM IS DEAD!!!!!!! |
