meeker22
#1 Posted : Friday, October 3, 2014 1:41:31 PM(UTC)
meeker22
Tested across the pins, Red bottom/black left 6.2
red bottom/black right 7.5
across the top 2 12.6
Is the compressor ok.
meeker22
#2 Posted : Friday, October 3, 2014 1:43:31 PM(UTC)
meeker22
The fridge is only 2 yrs old, hope it is good
#3 Posted : Saturday, October 4, 2014 1:20:15 AM(UTC)
Parts for Whirlpool GB2FHDXWB05 / Refrigerator - AppliancePartsPros.com
What is the problem?
The separate winding readings seem high (see the tech sheet) yet the in series reading seems low.
This may be just due to the meter.
In any case a winding resistance test can tell you if a compressor is bad.
It does not tell you that the compressor is good, as it may have internal mechanical problems.
File Attachment(s):
GB2FH.pdf (152kb) downloaded 1 time(s).
#4 Posted : Saturday, October 4, 2014 1:37:26 AM(UTC)
Testing with a 9 volt ohmmeter will not determine the windings are free from shorted turns, or burnt windings. Only a 115 volt test with an amprobe will determine status.
