tractorman1960
#1 Posted : Monday, September 29, 2014 1:36:38 PM(UTC)
tractorman1960
This refrigerator/freezer (side by side) never seems to have worked right. The unit seems to be always running and the door sides are always warm to the touch. Maybe the thing is stuck in defrost mode and the compressor is always running to compensate? I checked the ladder schematic which shows a "heater, freezer door" controlled only by a "safety switch". The wiring diagram shows the "door heater" wired to some components that are not well labeled. I suspect that there is a thermostat and a timer that controls these cycles but something isn't right and I'd appreciate some help on how to run it down. Also, the ice maker never worked either- maybe the problems are related? Thanks!
#2 Posted : Tuesday, September 30, 2014 12:43:07 AM(UTC)
Here are your parts, includes a wiring diagram
Parts for Frigidaire FRS26ZSEB4 Refrigerator - AppliancePartsPros.com
The unit will not be stuck in a defrost cycle as the compressor, the condenser/compressor fan and the evaporator fan are off during a defrosts cycle.
Check the freezer temperature. It should be between 0 and 5 degrees F.
If much warmer then this may be affecting the ice maker.
If is is colder then it could be a main control thermostat problem re: the unit is trying to reach too low of a set point temperature so runs all the time except during defrost cycles.
The constant running and hot side panels or section separator is often due to poor air flow around the condenser coils under the unit.
Check that the rear cover louvers and the front kick plate louvers are clean.
Check/clean the condenser coils under the unit.
Check that the unit is not pushed tight against the rear wall.
Check that the condenser fan is running.
Check/clean the condenser fan blade.
If all OK
Check that the evaporator/freezer fan is running OK.
If OK
Remove the cover in the freezer so you can inspect the evaporator coils.
They should have a fairly even coating of frost on them.
If there is frost only in one area (usually where the freon enters the coils) then it is probably a sealed system [problem.
You must be sure that the compressor has run for about an hour before doing this check. If you do it shortly after or during a defrost cycle you can end up with the wrong diagnosis.
tractorman1960
#3 Posted : Wednesday, October 1, 2014 6:43:49 AM(UTC)
tractorman1960
Thank you for your reply. Indeed I did find the airflow to be blocked by dust, etc. I will vacuum well and test the results. I'm still confused by the warm door sides. What is the function of the freezer door heater? Is it meant to come on during defrost cycles? Could it be continuously on if one of the controlling components is malfunctioning?
If all OK
If OK
#4 Posted : Wednesday, October 1, 2014 2:03:28 PM(UTC)
[COLOR="Blue"] What is the function of the freezer door heater?[/COLOR]
If you mean the one that is part of the ice chute dispenser it gets rid of condensation which could freeze the chute/trap door closed.
[COLOR="Blue"]
Is it meant to come on during defrost cycles?[/COLOR]
Looking at the wiring diagram it looks like it is on all the time.
