Is there a new design or fix for the very loud noise coming from the evaporator fan cover. The noise existed from the day it came into my house. the cover has been replaced 3 + times.
I put cardboard between the cover and back wall, thats all I can do unless you have other options
Check the evaporator motor, rubber end bell supports, may be weak and causing the problem.
