Doesn't cool. No freezer. it's a garage fridge. Evaporator Motor and fan works. Compressor works. Fan runs continuously. What should I check next?
Check the evaporator coils. If there is no frost/cooling on the coils then it is a sealed system problem and probably not worth fixing. |
THIS FORUM IS DEAD!!!!!!! |
thanks!...means i should buy a new one? $675 ?
[COLOR="Blue"]means i should buy a new one? $675 ?[/COLOR] Yes as the repair cost could be close to what a new unit costs. |
