Hello all. I have a 30" KitchenAid freestanding slide in gas range and oven I am getting the error code F1 E3 intermittently. The oven will work fine for a while and then will shut itself off and repeatedly give this code. The next day it will work fine. The oven wasn't moved recently and was just wondering what may cause this error code to come up all of a sudden. The code book says configuration mis-match check jumper cables. I didn't pull the oven apart to check the harness yet. Any help would be appreciated Thanks in advance
Joe
I ran an end of service test sequence and got the results 6AS Eb-SI
Heated up dinner just fine on the timer. I then tried to put it on 215 to keep dinner warm and it kept giving me all these funky readings and would then go off. No error code this time. It took about 5 minutes before I was finally able to get it to work again
Ok its still doing it. Oven stays on for a while and then just goes off. Pretty hard to cook dinner with this going on. If you have to open the door to check food while cooking 9 out of 10 times the oven spazzes out. sometimes you get the code, sometimes it gives you funky readings. Press 350 and out pops 80 or better yet 800 degrees or else you get a 250 temp probe Can anyone help Thanks
