Mark White
#1 Posted : Saturday, September 20, 2014 6:02:00 AM(UTC)
Mark White
I have a Frigidaire FES367ASG , last week while I was preheating it , I heard a pop, then noticed it would not heat up. The stove top works fine, I checked the element it's fine. I'm getting no power to the element wires. I called a technician to come look at it. The tech said he can hear the relay clicking when trying to preheat the oven, and he said its the Control Panel,... Then I had another tech tell me it could be my Control board, or that the Thermal circuit breaker needs to be reset. Any ideas?? Just don't want to pay $400 if its something simple like a reset button.
#2 Posted : Tuesday, September 23, 2014 12:18:49 AM(UTC)
Parts for Frigidaire FES367ASG Range - AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/p...assomption/318045067.pdf
Looks like the thermal circuit breaker is in the oven sensor circuit so if an error does not come up and the unit stays in preheat I would say that it is OK.
I would unplug the unit and check the wiring to/from the elements just to be sure it is OK.
