STEVE DOE
#1 Posted : Saturday, October 24, 2009 2:34:05 PM(UTC)
STEVE DOE
Side by side refrigerator- the compressor runs, but the condenser and evaporator fans do not come on at all. The defrost timer shuts off the compressor as I turn it through the cycle. I even jumped out the T-stat but no change. Please help-loosing all my product!
#2 Posted : Sunday, October 25, 2009 7:12:37 AM(UTC)
You have a simple refrigerator where both fans run when the compressor is running. I would suspect a bad wire, probably a ground wire at a connector. Also, both fan motors could be bad, you can remove either fan and plug into a wall outlet to check.
You will probably need a meter to check things, keep us posted.
