jfryjfry
#1 Posted : Monday, September 15, 2014 3:20:30 PM(UTC)
jfryjfry
Another case of oven stopped igniting, and I've educated myself a bit through this forum, but I still have a question or two.
I tried both bake and broil and both glow the same bright orange, but won't light.
If the broil lit, I would just order a new bake ignitor.
But I read somewhere that the ignitors are wired together to where if one is bad, it can keep the other from igniting.
So does it sound like most likely it is a bad bake ignitor (since we rarely use the broil) or because they are both glowing, could it be a bad valve??
Thanks!
