ScottnTexas
#1 Posted : Wednesday, September 10, 2014 10:47:49 AM(UTC)
ScottnTexas
:confused: Bosch dishwasher had burnt control panel -- was replaced, but then washer would not fill with water. Checked water supply, water valve (1000 ohms and opens when 120 volts put to it) Replaced water float valve.
If I put water in the washer, water heats and runs through cleaning arms, then drains washer. BUT, no water comes into the washer.
It seems as if the water valve is not getting the 120 volts to open.
Any suggestions on what to try next???
