rhemshot
#1 Posted : Saturday, September 6, 2014 7:19:07 AM(UTC)
rhemshot
The ice make only dispenses crushed ice and no cubed ice.
The solenoid switch for crushed/cubed ice works when I visually check by pressing the lever and the Saddle Solenoid is not broken . The Wire Actuator Disp is not broken and when twisted it lifts the Ice Deflector. Someone mentioned that it might be the Micro Switch but it works and that controls the water dispenser. I think all the functions on the outside panel work (water, crushed, light, temps.) but not sure if the issue could be the cubed function on the panel. If so, I would not know what to test on the circuit board with my multimeter. Could I be missing something else?
