The dispenser for the water is frozen at the lever in the door. I unthawed it at that point and it began working. Isn't there a heater that can be installed in the recess area?
Best to find out why it's frozen, most probable cause is the freezer too cold. Check the condenser for a clog, and set the freezer control for a warmer freezer temperature.
