Parts for Frigidaire FSE747GES1 Dryer - AppliancePartsPros.comCould be that the Start Switch contacts are welded together.
Unplug the unit and both wires at the start switch.
Then measure across the start switch with a meter.
Should be infinite ohms.
Should be o 0 ohms when activated (pushed or turned).
If the switch is OK then odds are that it is the electronic control board.
I am doing a bit of guessing here as I could not find a decent copy of the wiring diagram.
I doubt it is related to your heating element as the element circuit is separate from the motor circuit.
As an aside be sure to lubricate the rrear bearing with high temperature greas when reinstalling it.
It should be safe to run this way.
But as usual there is a but and in this case the but is that it will probably blow the door switch in time.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
I am off to the lake later today so will not be available till next week.
