Hi I have refrigerator ice is making but is not coming out while water does what can be
A model number may help others help you. Find your model number - AppliancePartsPros.com[COLOR="Blue"]I have refrigerator ice is making but is not coming out while water does what can be[/COLOR] Sorry but I do not understand the above. The last part of the sentence about the water seems incomplete. Could you explain what is happening? If you mean that the ice maker makes ice but does not eject it from the ice maker mold then there are a couple things to check. Check the freezer temperature. It should be between 0 and 5 degrees F. If the freezer is not cold enough the ice will not eject. If the ice maker has a ice bucket full arm check that it is not hung up re: the unit thinks the bucket is full so will not make more ice. |
THIS FORUM IS DEAD!!!!!!! |
