Washer failed abruptly with F35 and instantly got a new pressure switch cause I could get same day. No fix and the diagnostic failing on C00 so I got new CCU. Now I can do all cycles except clean washer (just drains continuously at start) and the diagnostic fails on C02 with a F20. Hot wash is hot, cold is cold. I messed with the pressure gage, and it appears I can start wash cycle fine without pressure hose attached-----and then blow in it fine to stop it. So it seems everything is indeed fine for normal washing.
It appears to me that there is a pressure issue on the low end? First part of clean washer is drain and it fails........maybe first part of C02 is make sure tub is empty?
Boggle (almost wished I totally failed and got a new washer)
