Kevinb123
#1 Posted : Tuesday, August 26, 2014 5:40:18 AM(UTC)
Kevinb123
Had this Washer just over 7 years and it's worked fine until the drain pump failed last week.
Installed a new pump, and now it continues to run.
I get a code IE which indicates that the unit is not filling - it doesn't fill due to the pump being on and evacuating the drum.
I researched on this forum where someone else had the same issue and had a service tech replace the main control board.
The control board is obsolete - after spending over 6 hours trying to locate a new board none are available anywhere except a few on ******** that are used.
Last night I downloaded the service manual and went the the Service tests.
The pump does turn on / off which leads me to believe the board may be ok.
I check the water pressure sensor and empty is reads 255, when full reads 255 so I ordered a new sensor.
I beleive the control thinks the unit is full so it turns on the pump at the start of every cycle.
I'll update the post if the sensor solves the problem.
