vansmack2
#1 Posted : Saturday, August 23, 2014 7:52:14 PM(UTC)
vansmack2
I have a KitchenAid KSFS25FJWH00. The Ice & Water Panel appears to have no power. The freezer door light does work with the switch as it should. I have read a few post about this. One post said the dispenser board may have went bad, and listed info on voltage checks to test the board. The other post said there may be some broken wires near the connector at the bottom of the door. My question is when I check the connector under the door what voltages should I get on the wires there? Please be specific as to what voltage on what color wire. Thanks.
vansmack2
#2 Posted : Tuesday, August 26, 2014 7:52:03 PM(UTC)
vansmack2
Anyone know these voltages?
