automaticman
#1 Posted : Saturday, August 23, 2014 4:48:43 PM(UTC)
automaticman
The Igniter won't lite up. I benched checked & it's good. I checked all fuses & switches. All good. I measure 26Vac @ the igniter plug with the drum removed, & motor running. Please help before I have to get a replacement. I've been at it most of the day. Thanks, Phil:eek:
fairbank56
#2 Posted : Saturday, August 23, 2014 6:05:56 PM(UTC)
fairbank56
Groups: Expert
Check the radiant sensor. Should be closed which applies full voltage to the ignitor. Could also be a faulty motor switch.
Eric
automaticman
#3 Posted : Saturday, August 23, 2014 8:21:46 PM(UTC)
automaticman
I'll check that. Thanks Eric
