Hey, I have a 25,000 BTU Frigidaire Window Unit A/C. It was working just fine and we turned it off last night and then we tried to turn it on this morning and it will not turn on. IT will not power up at all. The plug and the cord is good and there is 220 volts getting to the unit to the circuit board but I still have no indication of anything on the front of the unit. The board is almost $100 and I am trying to make sure if the circuit board is definitely bad before I order one. Thanks for any input you may have on this matter. Tommy
