I keep having a problem with the dryer and replacing the Thermal fuse fixes for short time. When you try and start the dryer it just clicks but doesn't turn on or start spinning the drum. First time it blew I just replaced the thermal fuse and it ran for 3 loads but then blew. Second time I made sure there wasn't any lint build up in the dryer and I made sure my exhaust line was cleaned out. It ran for a couple weeks but just blew again. Any thoughts on what I need to do next other than just replacing the thermal fuse?
Rank:: Advanced Member
If you replaced the thin, white motor fuse, your motor may be drawing excessive current.
