renaisanceman
#1 Posted : Friday, August 15, 2014 7:06:41 PM(UTC)
renaisanceman
Hello,
I have a water dispenser not working and no water to the ice maker. I checked the voltage at the water solenoid. Showing no voltage, I assumed the circuit board was bad. I just installed a new board and still no ice/water. While attempting to check the voltage again at the water valve/solenoid, a transistor on the board popped. Upon closer inspection, the same transistor on the original board was also damaged in the same way. I know I need another board, but what could be causing the repeated damage to the transistor? The water valve stopped dispensing water in the door initially and some time later, the ice maker stopped. Is it possible that the water valve/solenoid is damaging the board? Or perhaps the ice maker itself? Any advice would be greatly appreciated before I destroy another board.
#2 Posted : Saturday, August 16, 2014 7:30:23 AM(UTC)
If you have a foil heater in the back of the fountain wall, it's common for it to short, thus blowing the board.
renaisanceman
#3 Posted : Saturday, August 16, 2014 5:42:15 PM(UTC)
renaisanceman
Thanks for the reply richappy. The online manual does list a foil heater for a replacement part so I am assuming that it has one. I will check it out and test for a short. I am a little apprehensive about installing another $150 board!
renaisanceman
#4 Posted : Monday, August 18, 2014 1:46:33 PM(UTC)
renaisanceman
I checked the foil heater. I saw no visible damage and it read 4.74K on my ohm meter. Is that too high for the resistance reading?
