Mikeheff
#1 Posted : Wednesday, August 13, 2014 12:17:35 PM(UTC)
Mikeheff
The machine will not go into diagnostic model it goes to a timer 2min or blinks, I can hear a bunch of clicks by the CCU. any thoughts to whats up I have changed the door latch, ccu and the display panel so far nothing works
sidfink43
#2 Posted : Thursday, August 14, 2014 5:02:53 PM(UTC)
sidfink43
Wow, what you did should have fixed things. Use the tech notes you should have found under the top cover to test the motor control board, but the problem with Duets is that they are almost impossible to diagnose, even for Whirlpool techs.
